Hi,
So I bought a pre-built PC (this was during the GPU drought) that contains a 1080ti and since I bought it my thermals have been reading 60-70 C while playing Overwatch and Fortnite at 1440p 144hz and not even at max settings.
On my previous rig I was running a 6th gen core i7 6850k and a GTX 1080 1080p 144hz at max settings and my thermals wouldn't go higher than 50 C even while streaming. Due to a house fire I lost that PC and I bought a new PC (funny enough it was cheaper than my old one but I digress).
My new rig is speced as follows
Intel i7 7800X 6 Core Processor 3.6 GHz (Liquid Cooled)
32 GB of GSkill DDR4 3000 Mhz RGB RAM
11 GB MSI Geforce GTX 1080 TI
4TB HDD + 1 TB 960 EVO
Asus TUF X299 Motherboard
800W 80+ Certified PSU
I'm in a well air conditioned room and my PC is still running very hot. I have fiddled with the fan speeds and even at max speeds my PC will not drop below 60 C. I want to over clock in the future but I don't think that will be possible when my GPU is running this hot. Does anyone think they know a fix or why it would be running this hot on a more powerful graphics card. Thank you!
https://linustechtips.com/topic/953812-1080-ti-running-hot/
if the cooler has changed, thermals will change. What cooler did you use in the old system?
Desktop benching:
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589890
This new PC, what model is it?
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589898
Just now, Extremematt52 said:
I customized it on CyberPowerPc's website
What's the airflow like?
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589914
3 minutes ago, Extremematt52 said:
Can you clarify? I don't quite understand
I mean what cooling system did the two systems use. If the 7800x is cooled by a front mounted radiator, it will blow warmer air to the GPU, raising temperatures
also, 1080ti naturally produce more heat than a 1080.
Desktop benching:
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589919
Oh.... No its a rear mounted radiator sucking air out and I have 3 front mounted intake fans pulling air in.
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589927
1 minute ago, Extremematt52 said:
I have 3 intake fans at the front pulling through a mesh and outtake fan attached to the 120mm radiator pulling air out (Im not sure if that makes sense)
3 intake in the front, one exhaust in the rear/top?
Is there anything obstructing the airflow towards the GPU?
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589930
60-70C sounds about right for load temperatures, especially on a 1080Ti.
While under load, it makes sense that you wouldn't be able to/will have trouble getting below 60C.
That said, you don't have to worry about temperatures until you start to hit the 90C range.
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589958
6 minutes ago, Extremematt52 said:
Heres what it looks like. The top left is my radiator and the fan is behind it.
I'd just blame the 1080ti for producing more heat than the 1080 and therefore is more difficult to cool.
Desktop benching:
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589960
 The thing is whenever I see linus using a 1080ti in his builds he is able to overclock it with the stock cooler on the GPU so I thought there was an issue with my GPU
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589972
Maybe the thermal paste is badly applied, or someone forgot to remove the sticker on the heatsink.
Image result for sticker on gpu heatsink
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589978
you can overclock yours as well, 60-70C is cool enough. Wait till it hits 80C before you start worrying
Desktop benching:
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589979
I have a reference cooler on my GTX 780 and can overclock it just fine.
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589980
That's what im worried about. I think my thermals are too high to overclock
What are your temperatures at idle?
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589993
Okay I wasn't sure because that's pretty hot and wasn't sure how much of a hit my thermals would take from overclocking
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11589995
4 minutes ago, Extremematt52 said:
These are my idle temps
That doesn't look like idle temps. If your system was idling, Afterburner shouldn't report the speed to be normal base. Compare it to my GTX 780 at idle:
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11590010
Is the power management mode in Nvidia control panel --> 3D settings changed? Return it back to default.
Desktop benching:
https://linustechtips.com/topic/953812-1080-ti-running-hot/#findComment-11590020
