Hello guys, my idle temp is on 60°C.
Hardware:
Asrock z370 Extreme4
I7 8700k (atm not overclocked)
Cryorig quad lumi h7
Asus Rog Strix GTX 1080
2x 8 GB G.Skill TridentZ 3000 MHZ
Fractal Design Meshify C
2x Fractal Design case fans
The PC is 4 months old and i built it by myself.
Here are some screenshots:
HWMonitor:
https://gyazo.com/9e17a044f43a90f88fe0883d9aa4341c
https://gyazo.com/96289bfb77a34ca013eac827de53aa3d
Task Manager:
https://gyazo.com/9f2184a268dcdbb834c58ac8b850d35b
Coretemp:
https://gyazo.com/129e443dec652f8fd51fbfb32aadf8d6
I changed the thermalpaste and cleaned the cpu fan today but the temp is still at 60-65°C.
I am using the cryorig cp7 thermalpaste.
My Core Clock is always at 4.3 ghz. Can I save power and turn that on idle down?
Powersettings at balanced.
The ambient temp = 25-30°C.
I hope that you guys can understand my english. Its not the best.
https://linustechtips.com/topic/953654-cpu-idle-temp-~60%C2%B0c/
welcome to the Linus Tech Tips forums!
have you tried to overclock this system? if so, on bootup, spam the DEL key till you enter the UEFI. from there you'll want to reset your UEFI to stock F9 key (load UEFI defaults), then the F10 key to save and exit.
if not, you have something running in the background causing the CPU to stay at 4.3GHZ at idle.
