What are the best fans at cooling and are priced fairly for a pc? I want 2 case fans.
CPU-Intel i7-8700k
Mobo-Asus Prime Z370-A
CPU cooler-NZXT Kraken x62 Water Cooler
Ram-G.SKILL TridentZ RGB Series 16GB
Power Supply-EVGA 650W 80+ Gold G2
Case-NZXT S340 Elite
Graphics Card-GTX 1080
Current Pc Parts:
-CPU: Intel i7-9700k
-GPU: EVGA RTX 2070 black edition
-CPU Cooler: NZXT Kraken x62
-Mobo: Asus z390-E gaming
-Ram: Corsair Vengeance RGB pro 32g @3000MHz
-Storage: Samsung 850evo 256Gb
-Storage: Toshiba 1Tb 7200rpm
-Case: NZXT H500
-Extra: NZXT Hue 2
https://linustechtips.com/topic/953429-best-fans-for-cooling/
What are the system specs and where are the fans being used?
Where are you shopping / located? Budget?
https://linustechtips.com/topic/953429-best-fans-for-cooling/#findComment-11586235
CPU-Intel i7-8700k
Ram-G.SKILL TridentZ RGB Series 16GB Link: https://www.newegg.com/Product/Product.aspx?Item=N82E16820232498&cm_re=G.SKILL_rgb-_-20-232-498-_-Product
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
https://linustechtips.com/topic/953429-best-fans-for-cooling/#findComment-11586241
10 minutes ago, TheDeathDragon said:
I want 2 fan.
This is important. Are they case fans or rad fans?
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-Corsair Vengence LPX 32GB (2x16) DDR4-3600 CL18 / Storage-WD Red 6TB 3.5" 5400 RPM / Storage-Toshiba MD04ACA600 3.5" 7200 RPM--MSI SPATIUM M480 PRO 4TB 4.0X4 NVME--Samsung 980 PRO 1TB 4.0X4 NVME--Samsung 970 EVO 2TB 3.0X4 NVME--Samsung 990 Pro 2TB 4.0x4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-be quiet Light Base 900 DX / Fans-Noctua NF-A14 Cromax Black x10 / NZXT RGB & Fan Controller / PSU-SeaSonic PRIME 1000 W 80+ Gold /  Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / Memory-G.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Samsung 990 EVO 1TB 5.0X2 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / Fans-Corsair iCue SP120 RGB Elite x4--SP140 RGB Elite x2 / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Speakers-Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 5700X / CPU Cooler-Thermalright Phantom Spirit SE Black / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 / Storage-Samsung 970 EVO Plus 1TB 3.0X4 NVME--Patriot P310 2TB 3.0X4 NVME--Seagate Barracuda Compute 3TB / Case-CoolerMaster NR200 /  Fans-Noctua NF-12 x4 / Keyboard-Logitech PRO Tenkeyless / Mouse-Logitech G502 Hero / UPS-Cyberpower LE1000DG
Quote
CPU-AMD Ryzen 7 8700G / CPU Cooler-Thermalright AXP90-X53 Full Copper / Motherboard-Asus ROG STRIX B650E-I GAMING WIFI / Memory-Corsair Vengeance 32GB (2X16GB) DDR5-6000 CL30 / Storage-Samsung 970 EVO Plus 1TB 3.0x4 NVME--Crucial P3 4TB 3.0x4 NVME--Samsung 870 EVO 2TB 2.5" SSD / Case-InWin B1 Mesh / Monitor-ViewSonic VX1755 IPS 144Hz / Keyboard-Logitech K380 / Mouse-Logiteach G502 Lightspeed Wireless / Speakers-Creative Muvo Go
https://linustechtips.com/topic/953429-best-fans-for-cooling/#findComment-11586250
Case fans
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
https://linustechtips.com/topic/953429-best-fans-for-cooling/#findComment-11586253
29 minutes ago, TheDeathDragon said:
CPU-Intel i7-8700k
The case comes with 2 stock case fans which should already be enough. Adding a front intake or two would help but isn't strictly necessary.
PW2's are good: https://pcpartpicker.com/product/4GsKHx/be-quiet-case-fan-bl047
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/953429-best-fans-for-cooling/#findComment-11586323
