I don't really think it would. It'd also have to be a sufficiently large monitor, otherwise I would imagine the curved effect gets annoying to look at if you can see the monitor in its entirety easily.
https://linustechtips.com/topic/952858-monitor/#findComment-11581239
Curved monitors give great immersion, but it depends how far youre sitting away from it
If going ultrawide, definitely look for a curved one
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
https://linustechtips.com/topic/952858-monitor/#findComment-11581242
