OLD PC (LCD-386) - Need DOS to work
Solved by NelizMastr,
The date won't stick because the CMOS or RTC battery is stone dead and probably has been for 20 years. 1989 would probably be accurate, age wise, so use a DOS version that was relevant at the time. I'd say MS-DOS or PC-DOS 3.3 or 4.x.
Word of warning, you'll need to write 5 floppies if all you have is a 5,25" drive for MS-DOS 4.x. PC-DOS 3.30 only needs 2.
Download links:
https://winworldpc.com/download/57e2809c-331c-c2b1-c28f-11c3a6e28094 - MS-DOS 4.01
https://winworldpc.com/download/c2bb7b05-6ac2-ae6b-11c3-a4c2ac5a5404 - PC-DOS 3.30
