GTX 1060 using PCIE x8 instead of x16
mikevh
I have a GTX 1060 card, plugged into the first ( closest to CPU ) PCIx slot which is supposed to be x16.  The card is supposed to be x16 compatable.
Does anyone know how to convince the card to connect using x16?
image.png.31c029fdcca8f4d362c8a56346e2e093.pngimage.png.38fff7e9eaad5ae348f8c2b4fbb403d8.png
Do you have a ryzen APU? half of the PCIe lanes go to the integrated graphics.
Primary PC:
Yes, a 10gb network card. I just saw this in the manual from asus.  I'll pull that card and see if that does it.
Even then, I wouldn't worry about it. Even a GTX 1080 doesn't start suffering in performance until you hit the equivalent of PCIe 3.0 x2.
