USB TO SATA Adapter for Crystaldiskinfo
c00lFD
I want to buy a used SSD but the seller doesn't have a desktop and only has a laptop, that he doesn't want to take apart. Can I use a SATA to USB adapter for crystaldiskinfo to test it?
Get a new SSD, they're not that expensive and it comes with warranty.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
I was gonna buy a 500gb SSD, so good luck getting one of those cheap.
Have you even try searching?
Storage: Crucial - MX500 500GB M.2-2280 Solid State Drive  ($92.99 @ Amazon)
Total: $92.99
Generated by PCPartPicker 2018-07-26 00:46 EDT-0400
Price of 250GB SSD is around $70ish.
AMD ThreadRipper 2!
