Magni 3 and Modi 2
dome3731
Hello, I recently purchased a Magni 3 and Modi 2 and they sound like Schiit. Can someone help me make them sound better?
What headphones are you using and what are you using as your music source?
Is this a joke? You can send them to me if you don't like them haha.
Ensure you are listening to decent quality music files id say at the least something like Spotify premium (320kb's) or higher.
In your sound settings/playback devices on your desktop make sure you have enabled the correct sample rate under the properties for the Modi 2  &  check all connections, headphones, rca's , power etc just to rule that out.
Also like @Max_Settings said what headphones are you using?
I'm using the HD6XX and listening to Wav music
Do you have the Modi 2 set correctly in Windows with the correct sample rate?
I had it set to 24/96 when I was testing it against a cheap DAC/AMP SMSL M2
And I had all enhancments disabled
So what's wrong with the Stack?
It sounds the same as the cheap chinese dac/amp
Are you using high gain?
Yes
Yes
Hmmm well if everything is set correctly you must be mistaken or not know how to analyze a DAC/Amp setup. I have used both the M2 and the Stack and the Stack is much better. It is something that comes with practice.
Could it be my RCA cable?
Doubt it, but possible if they are really cheap.
Ugreen cables
Could it be that cable and also am I supposed to disable all enhancements or not?
Yeah disable all enhancements.
I just got a reply from schiit saying the bitrate should have been set to 24/192
I can't install their windows 10 driver. Says "USB 2.0 CDMEDIA not detected" or something like that.
Can you please help me install the drivers?
Quote
Gen 2/Gen 5 Drivers for Modi 2, Modi 2 Uber, Bifrost, and Gungnir
For Windows 10: Schiit USB Gen2 Drivers (W10) 1.01 (6.5MB)
For Windows 8, 7: Schiit USB Gen2 Drivers 1.16 (29.5MB)
Alternate drivers (if you have trouble with the above): Schiit USB Gen2 Drivers 1.03 (For 7 and 8)
Once you’ve downloaded the drivers:
Step 1: Go to your Downloads folder (or Desktop, or wherever you had Windows put the drivers.)
Step 2:
For Windows 10: Double-Click on the Schiit_USB_Gen2_W10_1_01.zip file to expand it.
For Windows 8, 7: Double-Click on the Schiit_USB_Gen2_1_16.zip file to expand it.
Step 3:
For Windows 10: Click on the Schiit_USB_Gen2_W10_1_01 folder to open it.
For Windows 8, 7: Click on the Schiit_USB_Gen2_1_16 folder to open it.
Step 4: Connect the DAC with a standard USB A-B cable, 2M or less in length, with true USB 2.0 rating.
Step 5: Double-click on setup.exe. This begins the driver installation.
Step 6: Follow the prompts from the installation program to install the drivers. You may have to restart your computer.
Step 7: In your Control Panel/Audio Devices, select the playback device. Depending on device, this may be "Schiit Modi," "Schiit Gen 2 USB" or, in the case of older DACs, "Schiit USB Audio Interface." You may also have to select the device separately in the player software you are using in order to get output.
Step 8: Enjoy your music!
Yes but I get a message "Please connect the CMEDIA USB2.0 Audio Device."
