Suggestions for Mixer and Headset
Solved by NinjaQuick,
Well, mixers aren't cheap. The Logitech mixer is not what you're really going to want. There are very low latency mixer software for pc, https://www.vb-audio.com/Voicemeeter/, for example, would let you mix game input with discord on the pc, but I don't know how much latency you'd be looking at. You can try it and see if it does the trick.
https://www.guitarcenter.com/Nady/MM-242-4-Channel-Mini-Mixer.gc should do the trick.
