Build for college/ transplanting a build
Hi there, so I'm in a bit of dilemma. I'm moving into a dorm room, and as such, I will not be able to bring my current setup as it is rather large. So I have two option either transplant what I can into an itx build and get the base leg gram or but an egpu and the more expensive LG gram and use that as my daily driver and my gaming machine, any help or suggestion is much appreciated. My current build and the possible new build will be linked below.
Thanks, Wayland64
The ITX build https://pcpartpicker.com/list/WB2Mw6
My current build https://pcpartpicker.com/list/QkFndX
If you dont already have a laptop for school, I would probably go the gram route
Though getting the parts for a the ITX transplant should be too expensive so possibly even get an ITX build and grab a cheaper laptop?
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
I wouldn't get an AIO that small, unless the case really can't fit a decent air cooler.
I also wouldn't buy a new motherboard. There's no need. You can save a ton of money getting something used. I'd also avoid MSI.
I wouldn't bother getting an eGPU. They're not that great.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
