Help me To choose Laptop
So i want to buy budget laptop for my everyday use and sometimes heavy use like Rendering1080p 60fps or gaming like fortnite (low)
i found a asus VIvobook S14 which has 2 type.
Asus S14 S410UF                              Asus S14 S410UN
Intel® Core™ i7 8550U Processor  . Intel® Core™ i5 8250U Processor
8 GB DDR3L 2800MHz SDRAM     . 8 GB DDR4 2800MHz SDRAM
MX130 2GB GDDR5 VRAM            . NVIDIA GeForce MX150 4GB GDDR5 VRAM
The S14 S410UF(left)  is 100$- 130$ more expensive than the right
i really confuse should i choose i7 or ddr4 with mx1504gb.  which one is the best?
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
The Asus S14 S410UN seems to be a better choice.
The i5 8250U performs pretty similarly to the i7 8550U and the MX150 is a bit better than the MX130, so go for the cheaper laptop on the right side.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
3 minutes ago, AskTJ said:
The i5 as it is cheaper, performs similary and maybe better with the better GPU.
i thought the same thing but, won't i7 is much more better than i5?
the max i7 clock is 4ghz while the i5 3.4 ghz
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
HardwareCanucks compared those two CPUs in a rendering test and they performed pretty similarly.
so the max clock doesnt affect too much?
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
i5-8250u vs i7-8550u = Minor speed increase. Almost unnoticeable
MX130 vs MX150 = 50% better performance! You probably won't even be able to play Fortnite properly on an MX130
The MX150 (25w variant) is crazy good for the relative amount of power and heat. You can play serious games on low settings, and competitive games comfortably
The cooling of this laptop won't allow the i7 to pull up too much more ahead of the i5 afaik
You get over 60 FPS in Fortnite at 720p medium settings with a MX130. I'm pretty sure that's playable.
so it wont go max clock and stay with same level as i5?
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
most likely yes
Vivobooks are mediocre in general, wouldn't recommend them
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
