Best dac/amp for DT 770 250 ohm
brandon32689
What would be a good Dac/amp combo for the DT770 250 ohms. I am looking to pair these with a modmic for gaming.
I've been happy with my FULLA 2 for several years now
http://www.schiit.com/products/fulla-2
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
DT770 should be very nicely capable, so would be shame to feed them only "sound inside left/right ear or in center of head" stereo speaker mix of games.
Because that's only positioning brain can give when signal lacks proper cues.
While if you have head shape close to average you could get 360 directionality.
Though they really aren't that demanding load (unless you want to lose hearing fast) so what motherboard you have?
I have the asus z270e motherboard. I guess I'm not to sure what your saying.
Human hears in 3D with two ears, because head and outer ears cause direction dependant changes to signal received by ears from sound source.
Those binaural cues can be simulated mathematically and most sound cards have had that feature for decade.
And if you head shape is close to average with accurate enough headphones immersion is very nice.
If you have those headphones disable sound effects of Asus software and listen first this standard stereo:
https://youtu.be/d1_20T8x_OI?t=12m57s
Not much of immersion compared to this:
https://youtu.be/d1_20T8x_OI?t=12s
