How much wattage do I need for a GTX 980 ti and a i5 8600k while bring overclocked?
6 minutes ago, paxterr said:
I'm making a new PC and I'm not sure on the PSU, I already ordered a 980 ti and the i5 8600k.
I want to overclock them both but I don't know if a EVGA - BQ 600W 80+ Bronze Certified Semi-Modular ATX Power Supply is enough.
600 watt should be enough, but it could be close, though I doubt you overclock like me, so it's probably gonna be fine. I would maybe look for a higher quality PSU though, something from around tier 2 or 3, the BQ 600 watt is tier 4.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
Yours faithfully
different 980ti will have different power limits, what's the model?
8600k will use 180w at most, under prime95. Worst case scenario, that is.
EVGA BQ series isnt that good though. Look for something with at least 5 years warranty.
3 minutes ago, Ryan.G said:
that would be enough, although i'm recommend to use at least 80+ silver for heavy overclocking
efficiency rating means nothing to the internal's quality. 80+ golds are far more common than silver these days anyway
Desktop benching:
according to tomshardware's test, their 980ti maxed out at 450w draw from PSU, lets say you keep your cpu stock and it uses 95w, you are already pretty close 600 watt mark.
id upgrade the PSU, i think the BQ series were a bit iffy with the protections and i havent heard off that being resolved yet. id get a 600W or a 650W unit, the G2 and G3 EVGA units are great IMO
*edit*
with a 980TI you might want to look at a 750W unit if you want, not strictly nessecary but the extra buffer might be a nice thing to have in mind if you want to really push overclocks :)
Builds:
Efficiency is not related to quality.
If tape can't fix it, nothing can.
