$3000 Canadian dollar build, with monitor and peripherals.
Daniel Z.
No OS, I would like it to have a consistent theme. It's for my friend. Here's what I've come up with so far. He will not overclock in any way.
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor  ($346.45 @ Amazon Canada)
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  ($78.99 @ PC-Canada)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($173.99 @ PC-Canada)
Memory: Patriot - Viper RGB 16GB (2 x 8GB) DDR4-2666 Memory  ($224.22 @ Amazon Canada)
Storage: Crucial - MX300 525GB 2.5" Solid State Drive  ($139.99 @ Amazon Canada)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($101.95 @ shopRBC)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card  ($689.99 @ Amazon Canada)
Case: NZXT - H500 (White) ATX Mid Tower Case  ($99.99 @ Newegg Canada)
Power Supply: Thermaltake - Toughpower Grand RGB 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.99 @ Amazon Canada)
Monitor: LG - 27MP58VQ-P 27.0" 1920x1080 60Hz Monitor  ($216.00 @ Vuugo)
Monitor: Pixio - PX277-N 27.0" 2560x1440 144Hz Monitor  ($509.99 @ Amazon Canada)
Mouse: Corsair - M65 PRO RGB FPS (White) Wired Optical Mouse  ($69.99 @ Amazon Canada)
Headphones: SteelSeries - Arctis 3 (White) 7.1 Channel  Headset  ($93.46 @ Amazon Canada)
Other: EagleTec KG011-RGB Mechanical Gaming Keyboard With LED Backlit 104 Key (White)  ($64.99 @ Amazon Canada)
Total: $2929.99
Generated by PCPartPicker 2018-07-15 01:44 EDT-0400
2 minutes ago, Sernefarian said:
That is a really solid build you have planned for your friend.
Would suggest saving some money and getting better response time on the 144hz monitor going with a different one though. This one eprhaps? https://ca.pcpartpicker.com/product/WyqhP6/pixio-px276-270-2560x1440-144hz-monitor-px276
Ok thanks!
1 minute ago, Daniel Z. said:
Ok thanks!
Though the other monitor does have IPS so viewing from off angles will be better for it. Both are important considerations.
Rawr.
I'll ask him what he prefers.
no point in the toughpower rgb since you can't see it anyways, pick up a rosewill capstone instead. why a 1080p 60hz monitor with a 1440p 144hz monitor?
Memory: G.Skill - Sniper X 16GB (2 x 8GB) DDR4-3600 Memory  ($224.99 @ Newegg Canada)
Storage: Crucial - MX500 500GB M.2-2280 Solid State Drive  ($142.00 @ Mike's Computer Shop)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($102.92 @ Mike's Computer Shop)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  ($667.98 @ Amazon Canada)
Case: Corsair - Crystal 460X RGB White ATX Mid Tower Case  ($169.99 @ Amazon Canada)
Power Supply: Rosewill - Capstone 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Newegg Canada)
Monitor: LG - 27MP58VQ-P 27.0" 1920x1080 60Hz Monitor  ($217.99 @ PC-Canada)
Monitor: Acer - Predator XB241YU 23.8" 2560x1440 165Hz Monitor  ($526.02 @ Amazon Canada)
Total: $2959.75
Generated by PCPartPicker 2018-07-15 02:45 EDT-0400
My guess on that the 144hz will be for gaming while the other will be to montior stream chats/web surf etc. while gaming.
Rawr.
Total: $2959.75
Ok thanks! The RGB would show out the back a little. (I know this is dumb)
