Can my power supply and motherboard handle a 1050?
Rotex
I bought this pc from eBay about a year  ago, and I later realised that this was a bad idea, but I bought it because I didn’t want to play any games on it and also I don’t know how to build one, so I just bought a pre-built one. Right now I’m trying to play fortnite on it but it looks like I’m playing on a ps1; the graphics are absolutely horrible so I’ve decided to buy a gtx 1050 gpu but I don’t know if my motherboard or my power supply can handle it. Im not sure wich motherboard I have but i do know wich power supply and it’s a atx-500cb
PS I Currently have a gtx 710 gpu
Yes.  That's enough power for a 1050.  The 1050 will draw less than your 710 actually.
A no-name unit powering a dGPU? That's questionable. I'd replace it with something like a Corsair CX450 or Cooler Master MasterWatt as soon as you can afford to.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
Are you sure? because the GTX 1050 does 70W under maximum load
The GT 710 should do 30W or even lower, it is a very basic card
You're right, it does have a lower power draw.  I was thinking 750ti or something.  Either way, though, the PSU will be fine.
Yes
