Budget hot swap case
TheGermanEngie
Does anyone know of a case that has hot swappable 2.5" drive bays? I'm looking on eBay but they're all server 2U racks and ATX cases that are overpriced af.
Most cases you'll find that are hot swapable are not budget friendly.
If you get a case with 5.25" front bays, you can always get an adapter. That would probably be my suggestion.
https://www.amazon.com/Kingwin-Tray-Less-Backplane-Enclosure-Performance/dp/B00475DQ6Y
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
That's great, thank you so much
As a side note (because I forgot to mention) the adapter in that link is a Dual 2.5" to 3.5" adapter, you'll need a (very cheap) 3.5" to 5.25" bay adapter to get this to function correctly
https://www.amazon.com/StarTech-3-5-Inch-5-25-Inch-Mounting-Bracket/dp/B000HLZXH2
