Save Power i5 3550 - NAS
Go to solution Solved by Jurrunio,
I assume you use the i5 because you already have one?
1. Disable cores. 2 cores is enough, dont need the other 2.
2. Undervolt the CPU. Better do this while you still have Windows, since you would want to use stress test tools there. Make sure you raise the final stable voltage by 0.1V before using it in the NAS machine, it will be annoying as hell if it crashed after being a NAS.
3. Use offset voltage rather than manual voltage. This allows the CPU to run on much lower voltages while sitting at idle.
Hello nice people out there,
i've build myself a freenas with stuff i had laying around and bought a 4tb for now.
Since im living in germany electricity is fu** expansive. ( 0.30€/0.36$ =  1 kwh)
Now i'm thinking how to save power on this machine. A i5 3550 + some mobo, 8G+2G Ram ,4tb iron wolf is in there right now, but
im adding a couple drives in a month or so and changing the OS to unRaid.
I was thinking to disable some cores and/or underclock/undervolt the i5 3550.
TL:DR: How to save power on this system(NAS): i5 3550, 8G+2G RAM, 5 HDD
Thank you guys.
What makes you think you need an i5? If the system is just for storage, you'll be fine with a Celeron or Pentium, and those have ultra low power T variants. Just swap out the CPU for a lower power unit :)
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
i dont need an i5, but i have on hand, from an old machine
Desktop benching:
