Which Wifi adapter should i get? Pci or usb? which model?
Howitz
I want to know if there's a wifi adapter model out there that stands out of the bunch, Thanks
PCIE will probs provide more bandwidth, and will also probs be a cleaner solution. Get a card that supports whatever ghz range you have, if you have 2.4 only, don't spend more on a card with both 5 and 2.4 receivers. get it from a reputable brand and one that has good reviews
I make intelligent lights do cool things
I'd get this... seems like a solid choice for 50$ cad
https://www.newegg.ca/Product/Product.aspx?Item=N82E16833704274&ignorebbr=1&_ga=2.55663275.107105353.1531273327-1771745347.1526425103&_gac=1.263457662.1531357348.CjwKCAjw1ZbaBRBUEiwA4VQCIZb3l5mmOdHLCiC9MH4i9mRmoH7LXYPSKNJmyW7wB7ZoMCsHXq9QYBoCWMQQAvD_BwE
ive used the TP link archer T9E got it for 100$ at canada computers and it wasnt that good worked for a few days then the range just reduced alot and my speed reduced. Usb adapters are alot better just spend 100$ on asus's best usb wifi adapter or get a range booster that also allows u to turn ur wifi connection to wired.
too late already got ac1300 t6e
