3.0 usb front panels, with 2.0 usb headers
If a case has usb 3.0 front panel ports, but the motherboard only has usb 2.0 headers, it would still work right? Just have to make sure before buying
1 hour ago, James Evens said:
You need a adapter to connect the usb plug to the mainboard. It will run at usb 2.0 speed.
Can you link some adapters? So i know which i have to buy
