Should i use for my 144hz monitor DVI-D Dual link or Displayport 1.2?
EdenAb
(Because displayport supports 120hz with G-sync and DVI-D Supports 144hz but with no g-sync).
Thanks.
If your panel is a G-Sync panel I would say go with Displayport
wait what displayport suports 120 hz only on a 144hz monitor?. 1.2 should suport to 240hz or I am wrong?
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
Depends on the resolution. Keep in mind that the interfaces are bandwidth limited and refresh rate greatly impacts bandwidth.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
