Dumb Question: Is it safe to put an external SSD on top of my PC case?
Realize this might be the stupidest question ever. For reference, I have a Fractal Design R5 case and I’m wondering if it’s safe to keep my external SSD (Samsung T5 500 GB) on top of the case.
Not sure what a safe temp range is for such a drive.
Any feedback would be appreciated. Thanks!
Why not, Use crystalDiskInfo to look at the ssd temp. If it is under 45C then all is good.
Sure it's fine, just make sure you're not blowing hot air on it constantly. Don't let it fall and pull the cable out, or damage the cable. Or you could just duct tape it onto the case or velcro it to the case like how I just duct tape my sound DAC on the case.
That works for external drives?
Only thing that would concern me is if your case is venting hot air onto it, or if it might block the ability of your case to vent.  If neither of those are an issue I can't see why it would be bad in any way.
Works for mine
I would say Samsung it really playing it safe - if you look in the manual for your drive they have written:
"Use the product in appropriate environment: temperature between 5°C - 35°C and humidity between 10 - 80%."
The humidity is very important, but a chip based disc only recommended up to 35C seems low, should be able to handle way more.
So I guess it's fine as long you dont place it in direct sunlight and exhaust hot air directly onto it...
My Gaming PC: 27833
Just pick up a cheap external case made for an internal ssd to be safe you can use it like any other ssd made to be external would offer some shock protection, that is shock as in banging it around
https://www.newegg.com/Product/Product.aspx?Item=9SIA1DS5AU2703&ignorebbr=1&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-External+Enclosure-_-9SIA1DS5AU2703&gclid=CjwKCAjwspHaBRBFEiwA0eM3kZhcWM2ZglRPeiZQgGjdH46QsFB70kesNg8IqAOosIEbDyl0sviJUhoCaLgQAvD_BwE&gclsrc=aw.ds
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
That’s actually a great suggestion! It should also keep it cooler, right?
Many SSDs allow you to monitor the temperature readouts from the sensors, but some do not. While mine is certainly not representative of modern SSDs(it's from 2012), I cannot monitor the temperature of the drive.
If tape can't fix it, nothing can.
