Dual e5450's stuck in auto repair
Tnab3r
So ive been putting together a server computer to host some games for my friends and i. It has an supermicro x7dwa-n motherboard with 2 xeon e5335's, which i upgraded to 2 e5450's. i have 32 gigs of ddr2 ecc 667mhz ram, and a gt730 i threw in for video.
I cant even get into windows 10 pro, just stuck on preparing automatic repair. im able to boot into windows xp pro that came with the system, but i couldnt get lan drivers to work, plus had a password locked admin account. Any help? also, first post, so if you need information, please comment, ill try to provide
Things I've tried
clear cmos
reset bios
different drive
different version of windows (win10 home wasnt even recognize as bootable, even with 1 cpu enabled)
full power down
reseating ram/cpu's
running win10 pro drive in different computer, works fine
Have you tried a fresh install of windows 7, 8, or 10?
tried windows 10 twice, dont have keys for 7. Both times windows 10 didnt get recognised, suprised it worked this time
Also, you could try swapping out the RAM
Did you install Windows 10 from the PC you are working on?
no, the computer wont boot from usb
i know ram is fine, all of it works in winxp and is all detected in bios
just because it all works in XP and is detectable in BIOS doesnt mean its fine.
RAM is weird that way. wont give u any grief until u do somthing it doesnt like and touches that 1 error on the stick and poof then goes away just as fast.
do yourself a world of good and run it threw 24hours of memtest to be sure.
cant even get windows 8 installed on it
i cant get into windows, thats my problem :) closest i have gotten is being stuck on the auto repair of windows 10 pro for 2 hours
do u have another computer ?
memtest doesnt require windows .. its bootable via USB stick
i have 2 other computers. but nothing server grade that takes ddr2 ecc
also, i havent been able to boot from anything usb, have had to install os on other machine, then transfer hard drive
do you have an optical drive you could put in it?
