-Moved to Troubleshooting-
Is there a click from the PSU when you try to power on? Did this just start happening? What are your specs?
https://linustechtips.com/topic/945075-pc-won%E2%80%99t-start/#findComment-11510299
It basically clicks, the fans turn on and then it just turns right off, it’s a msi z370 sli motherboard with an i7 cpu. It started happening the second I tried to power it on... It’s actually my brothers pc, but I had recently built one and it worked fine which is why I have no idea what’s wrong with this...
not sure if it’s a faulty cpu
https://linustechtips.com/topic/945075-pc-won%E2%80%99t-start/#findComment-11510352
