How do I connect RGB Fans?
UnwantedLinks
I have a Coolermaster Mastercase Lite 5 RGB and it came with 3 RGB fans but there is no RGB fan header on my Motherboard (Motherboard is Z370-A Pro). How else do I connect my RGB Fans? (The fans do spin but they dont show LED's)
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
Since that board has no RGB headers, your going to need a controller to wire up and control the fans. Coolermaster has their own software based controller.
http://www.coolermaster.com/cooling/cooling-rgb-accessories/rgb-led-controller/
-Moved to Modding Section-
Oh, Okay. Thanks
Main
So Do I connect it with a USB 2.0 Port?
Main
Yes it does need a USB 2.0 header for the controller.
Alright, I just ordered mine. Thanks, I was REALLY Confused.
Main
