Help w/ planning new build.
Hey again LTT community, I have been looking at lots of different parts combinations for a new build, and I am planning on re-using quite a few parts from various other past builds and just random stuff laying around.
I am looking at making a dual LGA2011-v1 socket build for various 3d design, virtualization, and occasional gaming tasks.
Also, I have a bunch of parts that I think may be of use in this build. How about I list a few:
*assorted 2gb and 4gb sticks of pc3-10600R Ecc registered RAM pulled from Dell and hp servers
*3x 240gb 2.5in ssds, assorted 500gb and 1tb 3.5in drives
*650w g2 EVGA PSU with dual 8pin eps12v cpu connectors, etc
*R9 390 Windforce, R7 260x, r7 240, gtx 960, gtx 645 (virtualization maybe???)
*Lots and lots of 120mm fans, mostly Corsair and a few 130cfm Delta jet engines as well
Parts I'm thinking of buying
*2x Xeon E5-2680-v1 CPUs (found a deal for them for $160 total)
*Asus z9pe-d8
*2x hyper t4
*Fractal define c tg (fits the mobo and coolers???)
What I need help with:
*Finding a compatible motherboard preferrably EATX or ATX (not e-eatx, ssi, etc)
*Finding a compatible case with my motherboard preferrably full atx or smaller, clear side panel, lots of room for cable management, mainly looking at nzxt, fractal, and be quiet
*Finding 2 matching cpu coolers compatible with all the other parts
*Keeping the $$$ spent under 600 for the cpus, 4x4gb ddr3 ecc to add to my existing 4x4gb ddr3 exc, cpu coolers, mobo, case, any other needed parts
Peace
Based out of Connecticut
"Night Train": i5-6600K, 16GB GeIL LED, G1 Gaming R9 390 Windforce, XFX 550W, Fractal Define Nano S
"Conplexitor": i5-3470, 16GB ECC (it works), GTX 690, EVGA 650W, Random off-brand midtower
"Busta": i7-2600, 8GB Mixed, Dell GTX 645, AcBel ?W, Junk cheap midtower
Sites:
gta5-mods.com/DevinKan
devinkan.ml
*Asus z9pe-d8
*2x hyper t4
Peace
  Reveal hidden contents
For a case you need one of these
https://www.cnet.com/products/yeong-yang-cube-server-case-yy-0221-tower-extended-atx/specs/
I had one before, lots of room. Though it did go "whoosh" on power up
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
What about the supposedly full atx Asus z9pe-d8?
Sites:
devinkan.ml
Wouldn't that fit in a full atx case?
Sites:
devinkan.ml
I don't know. I only have direct experience with the one I posted.
