[Solved] HELP! 2.2 GHz lock Ryzen 5 1600x
Go to solution Solved by Salacious B Crum,
I had a lot of problems with AIsuite I would get rid of that and start fresh and clear the cmos and do all adjustments in the bios that's how I got mine working and it was definitely AIsuite that caused it.
Specs:
CPU: AMD Ryzen 5 1600x
GPU: Asus dual fan (White) GTX 1060 3GB
MB:   Asus Prime B350 Plus
RAM: Crucial Ballistix (16GB, 2x8) 2666 MHz
PS:   Coolermaster Masterwatt Lite 500 (+White rating)
My Ryzen 5 1600x has locked at 2.2 GHz and i can not overclock it! I have tried Amd Ryzen Master, BIOS and AI Suite from Asus. I have also updated Windows 10 to 1803 and the BIOS to the newest version.
Acording to EZ update, all my drivers are up to date. I noticed that my ram is underclocked aswell, at 1,333 MHz. My ram is Crucial Ballistix 2x8 2666MHz
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
So what happens when you put 100% load on the CPU? Does the clock speed increase? This might just be cool 'n quiet doing its job when the chip is idle.
And 1333 is actually correct in terms of RAM speed. It's DDR memory so you have to double the memory clock speed to get the effective speed.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Also, try setting your windows power management setting to High Performance.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
If the CPU isn't fully under load, it wont go to its normal clock speed. It will stay at 2.2 until it goes under load. Run a benchmark like Cinebench and report back.
hi.
Windows is on Ultimate perfomance mode (Power setting)
Also i have put high performance on AI Suite
I have yet to try and clear CMOS
Im guessing that updating Realtek drivers wont help
Uninstall AISuite.
Restart
Check.
I myself have had issues with this software..... as have others.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Problem solved!
I uninstalled AI Suite and cleared cmos!
Thanks for all the help! :)
2 hours ago, olavpf said:
Problem solved!
Cool yeah don't know why that happens but it seems once you fiddle with AIsuite even if you decide to not use it it will remain contant and prevent other procedures from the bios from taking affect, as a rule I always suggest staying away from software that changes bios type settings they just seem wonky and I did have the same types of issues with my MSI command center software too
