Need A editing and gaming pc for 3k
Hello, so for some time now me and my gf have been wanting editing/gaming pcs for a long time if someone can help us with parts that are for 3k little above idc just make it beastly
i'd love you guys so much haha thx <3 <3 also monitors pl0x <3
What do you want to edit? 4K or 1080p? Which games at which resolution? Monitors included in the 3K budget or just the tower? Currency?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
here you go mate. Just grab a $20 Windows 10 key from a shady website somewhere and you're set.
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor  ($442.03 @ Amazon Australia)
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  ($86.00 @ Skycomp Technology)
Motherboard: Asus - TUF X470-PLUS GAMING ATX AM4 Motherboard  ($249.00 @ BudgetPC)
Memory: Corsair - Vengeance LED 32GB (4 x 8GB) DDR4-3000 Memory  ($505.59 @ Amazon Australia)
Storage: Samsung - 970 Evo 250GB M.2-2280 Solid State Drive  ($139.00 @ Shopping Express)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($76.00 @ Shopping Express)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($650.30 @ Amazon Australia)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($125.00 @ Skycomp Technology)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($105.00 @ Shopping Express)
Monitor: ViewSonic - XG2401 23.6" 1920x1080 144Hz Monitor  ($299.00 @ Mwave Australia)
Total: $2975.92
Generated by PCPartPicker 2018-06-30 00:29 AEST+1000
actually just one more thing is it possible to make the graphic card a 1080 and will I be able to render anything and get atleast 500-600 fps in csgo soz just curiosity
don't need two 144hz monitors replace one with 60hz cheap ips monitor and upgrade the gpu
1 hour ago, DudeThatNeedsAPCBuild said:
Australia Dollar, 1080p aka gaming videos and monitors can go as long as 144hz)
which programs will you be using for video editing?
Total: $2975.92
The R7 1700 is over $150 cheaper. Way better value.
https://au.pcpartpicker.com/product/3kPzK8/amd-ryzen-7-1700-30ghz-8-core-processor-yd1700bbaebox
8 hours ago, DudeThatNeedsAPCBuild said:
you sir are a fuckin legend :) thank you mate
Go with the R7 1700 instead as it is $150 cheaper. See my post above. That money can then be used for other things.
