Graphics card won’t post at all please help
Go to solution Solved by Zeke_,
Found my issue, the graphics card had wiggled just lose enough for it to be not fully connected to the PCIE-E slot thx for the help
So I’ve been dealing with an issue with my PC.  at first I was confused as to why it would not boot however after a little bit of tinkering and unplugging things and re-plugging things back in I figured out that the graphics card seems to be the problem child and refuses to post. I’m not quite sure what to do but may integrated graphics work just fine.  I’ve only had the card for about a month.
#BudgetMasterRace
CPU: Pentium G4560  GPU: Gigabyte GTX 1050 OC  RAM: 8GB DDR4 2400mhz  CASE: NZXT S340  POWER SUPPLY: EVGA 500B MOTHERBOARD: Gigabyte B250M-DS3H  STORAGE: 1tb Wd Blue 7200rpm hdd  MOUSE: Redragon M711 Cobra Chroma RGB
KEYBOARD: Corsair Strafe  MICROPHONE: Blue Snowball  DISPLAY: Dell S2440L 1080p 60hz  HEADPHONES: Audio Technica ATH-M30X's
if you plugged the hdmi or display port cable on the motherboard unplug it and put it the cable in the gpu its a common mistake
I’ve done that but the card just refuses to post. The card turns on and gets the fans spinning and what not it just won’t display anything.
#BudgetMasterRace
unplug the card clean it, especially the dust
 The card is brand new I only got it a month ago.
#BudgetMasterRace
Make sure you're using pci-e power and not something else (although other power connectors shouldn't work)
i7 8700k @ 5.0Ghz | ASUS Strix Z370-F Gaming | Cryorig R1 Ultimate | 16GB Corsair Vengeance LPX DDR4-3000 | ASUS Strix GTX 1080 8GB (A8G) | WD Black 500GB PCIe NVMe | Samsung 750 EVO 120GB | Western Digital Black Series 1TB | Fractal Design Define R6 TG | Corsair RM750x
"Everyone says that I'm incredibly unlucky at the Silicon Lottery. In truth, I just persist in believing that 106°C is an acceptable temperature."
- Me, 2018
Also try a different port on all devices, since gpu ports can easily be killed by esd as well
- Me, 2018
How do I check that I’m using PCI-E power?
#BudgetMasterRace
what are the specs of the system?  did the card ever work?
Did you set the graphics card to be the primary display adapter in the bios.  If you are on a modern system with a modern graphics card its possible that you may need to enable csm in the bios to get it to work.
#BudgetMasterRace
