Lian Li PC O11 Dynamic - White UK stock
delroyjones
Hello
Does anyone know anywhere that has this case in stock that ships to the UK? I can't seem to find it anywhere!
Lian Li has never been well distributed in UK... I see OcUK and watercooling UK list it but both are not in stock. You could ask them if they expect more any time soon.
Main system: i9-7920X, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance LPX RGB 3000 8x8GB, RTX 4070 FE, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
The problem is that neither distributors nor wholesalers get a lot of stock for Lian-Li if any at all. Some of the biggest ones in Germany have 0 Lian-Li products.
If you want a proper answer, you should probably ask your local retailer or the company directly.
I ordered mine from Caseking a while ago, when the new stock was expected on the 27th - it's now been pushed back to 11. July, so hope I get mine from that batch. :(
 c u r r e n t  /  ROG MAXIMUS Z690 FORMULA  /  I7-12700K  /  2080TI  /  32GB DDR5  /  LIAN LI PC-O11 DYNAMIC
 Z170 STINGER  /  6700K  /  TITAN X  /  32GB DDR4  /  NZXT MANTA  /  j u i c e b o x  build log
nohasslemods
