G. SKill Trident Z RGB does not show up in Asus Aura
Zexion
Go to solution Solved by Dissitesuxba11s,
Have you tried reseating the RAM? Couldn't hurt to try.
Hello guys. I am not sure where this belongs, I hope here is the right place.
So... Today I upgraded my Gigabyte Z370 Aorus Ultra Gaming to an Asus ROG Z370 Maximus X Hero.
I deinstalled everything from Gigabyte and installed a few things from Asus.
But in my RGB RAM is not showing up in Asus Aura. Do you guys have any idea why ?
I have the newest BIOS & Aura Version
Thank you for your help ^^
Do you mean take it out and put it in again ?
Yes ... I can try that.
No... did not work...
Even ASUS Aura stoped working. I reinstalled the software and now it is there... thank you ^^
For that to show up in Aura you need to go into the BIOS and enable SPD Write on the RAM. It is disabled by default on Asus boards, but enabled on most other brands.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
  • 3 weeks later...
I had Asus Aura and both my G Skill Dimms appearing fine, then I've added more RGB items (some fans, etc) and DIMM 0 doesn't sync, DIMM 2 is still fine.
Uninstalled Asus Aura (which was nearly impossible, needed to use Revo Uninstaller), and AI Suite 3, re-installed them both, still exactly the same issue.
Not sure who to be mad at Asus or G Skill, they were both working no problem, now the first DIMM has gone completely rogue for some reason kinda annoying.
  • 1 year later...
i have that problem to and i just turned off the power power supply and waited like 2m and next i turned on pc and it showed
