Mount wont stay up?? Help!
Solved by dizmo,
You've messed up the tension mechanism somehow.
It wouldn't be 5kg total, otherwise it wouldn't be able to claim 27" monitors would work.
If you can return it, I'd look into getting 3 separate gas strut mounts. They're a lot better, and just a little more expensive.
Featured Topics
FoxoJack ·
Posted in Troubleshooting0 -
1
ricktheduck ·
Posted in Troubleshooting1 -
1
LoricaSefu ·
1
11
2
