PSU with 2 8-Pin EPS
ivanteng880
Hi I'm getting a Gigabyte arous gaming 7 X470 motherboard and it have one 8 pin EPS and a 4 Pin EPS and I need a power supply with 2 8 pin EPS, any suggestions? And I need one under 80 dollars US. Please no EVGA one, My friend got a EVGA PSU and it loud AF, so no EVGA. I'm open to suggestions. Thanks in advance.
Do you really need dual eps? Those boards work fine with a single and unless your running ln2 or simmilar the single 8 pin is more than enough power for a heavy oc.
are you sure, because if they are enough why would they put dual eps in anyways?
Mainly because they can, a single 8 pin can deliver more than enough power for any cpu on that socket.
Okay. Is EVGA supernova G2 as loud as G3? Are EVGA PSU really that loud? some people say they scream like someone is being burned alive and some people say they can't hear it at all, which one is true. ?
If you want a quiet psu id look for one with a fan cut off at idle and with a higher wattage so the fan stays off most of the time.
Also depends on what you call loud, people have different standards.
If my friend bought an nVidia GTX1050 and complained it's slow, should I avoid any nVidia graphics cards altogether?
Not all power supplies of one brand are made equal. Not all models of any brand of consumer product are made equal.
