I5 4460 with ddr3 better than i5 7400 drr3?
Hi guys i want to change my cpu and i want to keep my ddr3 8gb ram
Is it better to buy an 4460 which officially support ddr3 or is it better to buy an i5 7400? (With the ddr3 1600 mhz)?
I mean i5 4460 and i5 7400
The 7400 isn't that much better, and there's definitely no reason to get a 7400. Either stick with what you have, or buy an i5-8400 (with a new motherboard and RAM) and sell your old parts.
Edit: Sorry, I misread. I thought you wanted to update from a 4460 to a 7400. Honestly, if you want to get a quad core I'd suggest selling your old stuff and getting an i3-8100, which you can upgrade later. It will probably cost you less since you can sell your old RAM, and an 8100 is faster than either the 4460 or 7400.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Your DDR3 RAM modules will not be compatible with the motherboard for your i5 7400. You should buy DDR4 when you want to use a Kaby Lake CPU/motherboard (which is more expensive).
No LGA 1151 motherboard support DDR3. One of the main features of LGA 1151 is that it uses DDR4 exclusively.
https://www.amazon.com/Gigabyte-Motherboard-DDR3-2600-GA-Z170-HD3/dp/B013TAU4IU
They're rare, but they exist.
2 minutes ago, Christophe Corazza said:
Holy $H!T o.O What kind of monstrosity is that :P
I didn't knew they existed!
They work with Coffeelake as well, if you hack the BIOS.
idk
Using DDR3 1600 does hit the minimum frame rates in games heaviliy though.
Desktop benching:
@Pdouros
Barely, and you are better off just getting an; i7 4770/4770k, i7 4790/4790K or Xeon E3-1280 v3/v4 (it has to be either v3 or v4-and do a BIOS update if you plan on getting one).
Any one of them is far better in all tasks than the i5 7400
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
That was me when I wanted to go with 1151. Saw that the G4560 supported DDR3 ram so I was like "F*CK YEAH", but I got a Haswell i5 anyway.
OP, don't get the i5 7400. Just not worth it at this point in time. Either get 8th gen or the 4460, if it cheap.
hi.
13 minutes ago, Droidbot said:
hmm where did I read that someone gained 20% better minimum frame rates by replacing DDR3 1600 to DDR4 3200 after the motherboard broke? I think it's some HardOCP post, but I cant find it anymore.
At least 10% is something.
Desktop benching:
I underclocked my RAM from 2133Mhz to 1600Mhz and that made a huge difference in gaming.
I didn't have stable 72 FPS in BF1 64 player multiplayer anymore and big explosions caused annoying stuttering. Watch Dogs 2 also stuttered badly while driving around city and the lowest FPS i saw was 43 FPS. CPU usage was 90-100%. I'd say minimum FPS was around 20-30% lower in CPU heavy games after underclocking RAM. My CPU is i7 6700 which is faster than i5 7400.
Intel Core i5-13600KF @ 5.4/4.3Ghz (P/E) / Noctua NH-D15 chromax.black / ASRock Z790 PG Lightning / 32GB Kingston Fury Beast DDR5 @ 6400Mhz CL32 / PowerColor Radeon RX 6950 XT Red Devil 16GB @ 2700Mhz / Samsung 980 Pro 1TB / WD Blue SN570 2TB / Corsair RM1000x / Lian Li Lancool 216 / Lenovo G27Q-20 (1440p & 165Hz IPS)
3 hours ago, JoostinOnline said:
I remember those from Skylake launch, but I (incorrectly) assumed Kaby Lake would have dropped support for DDR3. After a quick visit to Ark apparently the 7400 does support DDR3 too...
https://ark.intel.com/products/97147/Intel-Core-i5-7400-Processor-6M-Cache-up-to-3_50-GHz
I know ram pricing is still a pain point, but doing this to reuse only 8GB doesn't seem worth it.
Main system: i9-7920X, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance LPX RGB 3000 8x8GB, RTX 4070 FE, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Indeed. It’s a nice piece of tech but I don’t see the point of it nowadays.
