Compatiblity for my new build, need help
Hi guys so im planning to get:
Ryzen 5 2600
R9 280X (FOR FREE)
GIGABYTE GA-AB350M-DS3H
and the RAM - DDR4 8G / 2400MHZ CL16 Crucial Ballistix Sport LT White
SSD 120G Kingston
My question is : everything is compatible? especially RAM?
thanks !!
I think you might want to get an x470 mobo instead to not have to update the mobo but I might be wrong cuz I dunno much about AMD as I am an Intel peasant.
poop
As mentioned above, either get an x470 or have a backup plan to get the BIOS updated if your board arrives without a compatible BIOS on it.
Additionally, get a dual-channel kit, you'll see a lot of benefit from it with Ryzen.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
I'm not building it myself I'm getting it installed by a certified PC company in my country, I'm pretty sure they will update the BIOS
Also I'm looking to get another 8gb in the future that's why the single channel for now
My question for now does everything fit? especially ram with the mobo?
