Forwarding Ports for Xbox?? MikroTik
Solved by brwainer,
58 minutes ago, AMD Lover said:
On the General tab, take the ports you have in "Src. Port" and move it to "Dst. Port". Then on Action put in the same port number. Your Plex Server rule appears to be correct, although I can't see the "To Ports"column in your screenshot (it isn't added by default, you can do so by clicking the down arrow to the right of Packets)
specsdude99 ·
Posted in CPUs, Motherboards, and Memory1 -
1
2
4
1
Tydn12 ·
Posted in New Builds and Planning3 -
2
ID0 ·
Posted in Networking2 -
eviohh ·
Posted in Troubleshooting3 -
5
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
