Altec horn + 15" woofer system
spwath
Thought I would share my latest creation. Cost me only $350 to assemble.
Uses altec 811b horns, emilar compression drivers, jbl 2226h woofers, and jbl pa cabinets. I had to enlarge the horn whole to fit the altec, and add an l pad to tone it down. Result sounds great. Weigh 85lbs each. I get good volume with 60% volume on my 3w tube amp. I also have a 400w amp for next year. I plan to bi-amp as well.
This looks like the bastardized amalgamation of what our "eccentric" family friend would come up with.
10/10 for still owning a CRT, Boston poster, Mac?, and what appears to be a fantastically tiny cluttered room with two gigantic speakers.
#Muricaparrotgang
Crt is for super smash melee, Boston poster is actually an lp, and Mac is emptied out and used to store alcohol. I have another non gutted powermac g5 under my desk for when I want to uhh.. use a computer with an old os and a cpu architecture that can't run any modern programs.
Sounds remarkably useful. A Mac liquor cabinet intrigues me.
#Muricaparrotgang
Works well. All aluminum nice design, built in place to lock it shut, and unassuming.
I question the need to lock your liquor in a $5000 "cabinet."
#Muricaparrotgang
Well I got it for $100 on Craigslist, and at some point gutted it for some reason. Motherboard is on the wall. Was sitting behind my couch for a while until I thought "hey this is a good place to put liquor"
Please tell me your not using those speakers in that room...
#Muricaparrotgang
For now I am. When I go back to college I have a bigger space for them.
Listening to "Selling England by the Pound" by Genesis right now, and they still sound great in my tiny 10x10 room with a loft bed, large desk, couch, and a whole bunch of other shit.
5 minutes ago, InvertedEar said:
Holy shit. Good job, man.
Wasn't too hard, just needed to widen some holes, solder some wire, and screw some stuff in. Makes for a great sounding and indestructible 85lb speaker.
Just now, elira said:
Are you using a custom crossover?
Right now I am using the crossover that was in the speakers, at 1.1khz, but plan on biamping with a minidsp.
I'll do some measurements outside tomorrow and post them.
Thats a 16 ohm 30 Watt horn  how you running that off 3Watt tube amp?
where you get those specs from? I didn't even list my specific driver.
Its 8 ohm, 100w.
sensitivity for the horn is 100+ db. The woofer is 96db.
I use the tube amp at about 60% volume, but I am only about 2 ft from the speakers/.
Horns are very efficient.
I'll be bi amping them. Just got this Myryrad MA-120 60w/channel amp for the bottoms, getting a nice 10w/channel amp for the highs. Will be using a mini dsp for active crossover. Also picked up a nice Carver CT-7 pre amp.
  • 4 weeks later...
Got my bi amped system set up with the minidsp
I spy a jonokuchi
PEWDIEPIE DONT CROSS THAT BRIDGE
6 minutes ago, Gofspar said:
I spy a jonokuchi
Yup, driving my tweeters, and headphones.
