Should This Build Be Changed to X299 over Z370? (First Build)
Solved by Electronics Wizardy,
Unless your doing tons of bandwidth with storage or network(you don't seem to be) it will be fine.
4
Inception9269 ·
Posted in PC Gaming0 -
Chimneyfan52 ·
Posted in Troubleshooting4 -
2
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
