Search In
  • More options...
Find results that contain...
Find results in...
Buying Parts Soon. Tell me if I should change anything.
Hello, my name is Patrick. I am 15 years old and I have been on this journey to build my first ever pc for awhile now. And I think I have finely got the perfect build. I want a pc that can run games at 1080p max settings. with atleast 60fps while live streaming and/or recording. I will have 3 monitors. one at 1080p 100+ hz. and 2 others at 60hz 1080p. Tell me if I need to change anything. Is my motherbored good? Is my CPU and GPU good for what I need it for? I just need opinions.
My Build: https://au.pcpartpicker.com/user/Patrick4325/saved/H2tvVn
Looks like a solid build that will do what you want it too very well. However a CD reader for $89 is quite un-needed unless you have a library of old games and movies you need to watch off a disk. Im a "power user" of PCs and have been for like 4-5 years. I have not ONCE needed to use a physical disc, ever. And If I needed to do something with it, I can do it with a USB or CD player emulator (free).
Gaming - Ryzen 2600x | 16GB 3333mhz  Vega 56 | 500GB NVME 256GB SSD
Gaming 2 - Ryzen 2600x | 16GB 3400mhz  GTX 980ti | 500GB SSD | 6TB HDD
Home Server - Ryzen 2700x | 16GB 3400mhz |  RX 550 | 500GB NVME 11x2TB HDD
One could argue those fans aren't worth it either, however it will certainly improve airflow. for me $90 is a steep price for very marginal airflow improvement depending on what fans the case will come with.
Consider some changes.
Replace the two drives with a 1TB ssd.
Use a 550W psu. It has more than enough capacity.
Use the three stock case fans and don't bother with the Corsair ML fans.
The Windows 10 OEM license, at least in N.Am., does not permit use in DIY builds. One is supposed to use a retail license.
As others have noted, unless you plan to watch and/or burn Blu-Ray disks, the optical drive is overkill.
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor  ($459.00 @ Skycomp Technology)
Motherboard: ASRock - X470 Taichi ATX AM4 Motherboard  ($339.00 @ Scorptec)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($269.00 @ Umart)
Storage: Crucial - MX500 1TB 2.5" Solid State Drive  ($339.00 @ Umart)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($669.00)
Case: Cooler Master - MasterCase Pro 6 ATX Mid Tower Case  ($184.00)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($139.00 @ Mwave Australia)
Optical Drive: Asus - BC-12D2HT Blu-Ray/DVD/CD Writer  ($83.00 @ Skycomp Technology)
Operating System: Microsoft - Windows 10 Home Full 32/64-bit  ($145.00 @ Shopping Express)
Total: $2626.00
Generated by PCPartPicker 2018-05-09 13:08 AEST+1000
