Corsair Commander PRO (RGB Strips, RGB fans)
Solved by W-L,
1 minute ago, InsanityPC said:Okay so then I wont bother Getting the Node Pro + RGB strip package and get the Commander Pro, and I'l probably go with the LL series fans.
Thanks for all your help!
Just something to note if you get the 3 packs of the LL fans they do come with a lighting node pro itself and the needed 6 port RGB hub for wiring up the RGB fans.
- Prev
- 1
- 2
- Next
- Page 1 of 2
- Prev
- 1
- 2
- Next
- Page 1 of 2
Share
Followers
3
