difference between kaby and coffee
Solved by themctipers,
the difference is more cores across the board
i3 8100 is 4c 4t, while on kaby lake an i5 would be 4c 4t
i5 8600 is 4c 8t, while on kaby that would be an i7
i7 8700k is 6c 12t, which would've been enthusiast (x299)
also slightly higher base clock speeds and maybe 50mhz faster iGPU, no IPC gain, just mainly more physical cores.
decolon ·
Posted in Troubleshooting4 -
Rostovne ·
Posted in New Builds and Planning2 -
2
1
IceTeaSRB ·
Posted in Networking14 -
2
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
