MSI AERO 1080 8GB EXTREME TEMPS
Jawzz
My MSI Aero 1080 8gb card is hitting extreme temps.... going up to 90-92 C... when it goes to 92 degrees the fan speed goes to 5400 rpm. Also, nothing besides pubg/discord are open at the same time
Maybe the graphics card is being choked of air. What case do you have, maybe it's restricting airflow.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
reference card, somewhat normal
make fan go faster
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Yep
NZXT S340
1 minute ago, Jawzz said:
NZXT S340
How's your fan setup, how many intakes/outtakes, how many fans, etc.
3 hours ago, Jawzz said:
NZXT S340
how are your fans setup?
13 minutes ago, Jawzz said:
NZXT S340
How amny fans do you have? intake/exaust? any aio cooling?
One AIO with 2 intake and one outtake
Is anything overclocked?
Just my 6700k from 4 GHZ to 4.2
Thermal paste dried off? They put so little on cards these days. Dont try check it yourself though since it might void the warranty. Send it back for MSI to do it. You can call this a last resort option.
9 minutes ago, themctipers said:
make fan go faster
it's somehow at 5.4k rpm. faster than many diesel engines are capable of reaching. I wouldnt push further than that.
Desktop benching:
It only goes to 5400 rpm when its at 92 C if its <92 degrees it stays at 1980
https://gyazo.com/9ed0df6a94bf433543af6f2100df41ab
I would reapply thermal compound to solve this temperature problem of yours.
ok thanks
