Best fans for H115i?
gundamMC
I'm looking for some new replacement fans for the h115i, the stock ones are a bit too loud for me.
After going through various pages it seems like its one of the three:
  • Noctua NF-A14
  • Corsair ML140
  • Thermaltake Riing 140mm
I don't really care about aesthetic since my case (Phanteks Evolv ATX) is on the ground and facing me directly so I won't see it anyways. xD
Any recommendations? Thanks
I would personally get the Corsair ML fans, going by all the reviews I've read/seen, they're the quietest on the market even at full RPM. Good static pressure too.
i have a pair of noctua industrial 3000RPM fans on my 115, and i have them set pretty low speed. i can hear them, but just barely. and they keep the water temp pretty cool.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
The Riing fans worked out really nicely back in the day for me. But the ML series is also really good. I would go Noctua if you don't care about the looks and ML or Riing if you do.
print "Hello World!" ("Hello World!")
Thanks! I just noticed the Be Quiet Silent Wings 3 fans; how do those compare to the ML fans?
SW3's quieter than the ML's but can't perform as well if you want to run them at high rpm.
NF-A14's are better than SW3's at lower rpm but are more similar at moderate to high rpm with High-Speed SW3's.
Riings are fairly quiet but don't perform as well as the other options mentioned.
If you want potential for higher performance, ML's are great. If you're focused on a very quiet system, NF-A14's would be better.
DO NOT use those for the h115. I tired them, they are GARBAGE for that application. GREAT airflow fans, but are terrible at building the static pressure needed.
I've gone through 3 iterations of fans on my H115i: Corsair stock, BQ! SW3, & Noctua Industrial (the black fans). The noctuas are by far the best of what i've tried so far.
System specs:
