Freezing and loud buzzing sound followed by shutdown and restart.
Solved by da_knug,
For anyone following this, or finding it in the future because of similar problems, I have concluded that the problem in this chase likely was CPU related, namely the CPU being starved of voltage as I had applied a moderate 5.0GHz OC and then set an adaptive voltage with a negative offset of 100mV. I lowered the offset to 75mV and haven't had a crash since.
gsgloden456 ·
Posted in PC Gaming0 -
kacper6768 ·
Posted in Displays1 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies1 -
2
RagePoweredGamer ·
Posted in Troubleshooting19 -
14
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
