Zero RPM psu on low load, low wattage, lowish price
1 hour ago, saras said:I'm looking for a low wattage PSU that doesn't engage its fan on when the system isn't at load. The problem is that google only really gives me PSUs with ridiculously large wattages for my intended use case.
No, you want a PSU with a good fan and low RPM (500rpm or lower).
The ones that come to mind are Cougar LX (too expensive), be quiet Pure Power 10 (400W and up), Straight Power 10 and 11.
And surprisingly Xilence Performance A+ and X, though the other ones are better...
Semi Fanless doesn't give you anything if the manufactorer didn't cheaped out on the fan...
1 hour ago, saras said:This is for a potato build for my mum, basicaly 2200g or 2400g and no GPU. So I'm not really expecting on breaking 100W's here
Sadly there are no good quality PSU under 400W on the market right now.
And if there were, they wouldn't be any cheaper than the 400W counterparts...
