Base clock stuck at 0.79Ghz, 100% utilization (7700K, Z270-E)
Solved by Clyne,
4 minutes ago, Cotroneo said:I just checked in the BIOS, and it has the BLCK set to 800Mhz for some reason.
How do I change this?
If you're seeing 800MHZ, that is FCLK frequency.
BCLK is under AI Overclock Tuner with XMP/Manual
1
Bory Brason ·
Posted in Displays3 -
2
Da_maniaC ·
Posted in Peripherals2 -
Evan37 ·
Posted in New Builds and Planning2 -
1
HYSTOU ·
Posted in Laptops and Pre-Built Systems4 -
Sychicyuto ·
Posted in Troubleshooting11 -
noidea213 ·
Posted in Graphics Cards2
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
