PC sometimes takes longer than normal to shutdown
Solved by Sergio45,
Tried everything that was recommended and with no results.
What I did that seemed to fix the issue is the following:
*In advanced power options disabled: USB selective suspend setting.
*In "Choose what the power buttons do" disabled "turn on fast startup".
*In my bios enabled: EuP 2013.
Doing a few shutdowns.The PC turns off within a matter of seconds rather than minutes.
Thanks guys for all the recommendations.
