Weird Drive Problem - No urgent fix needed, but it is annoying
Solved by noobPCgamer,
Fixed the issue. It turns out it was simple enough to fix, AHCI drivers were not properly installed, once I fixed that all the drives work perfectly.
If anyone needs it here is a tutorial for fixing it: https://goo.gl/io1pch
txmatt1214 ·
Posted in New Builds and Planning1 -
1
Nevan Nedall ·
Posted in New Builds and Planning5 -
3
Littellittel ·
Posted in Troubleshooting0 -
2
ShadowBroker50 ·
Posted in CPUs, Motherboards, and Memory0
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
