RM650X MAKES A POPPING NOISE
Solved by Guest,
21 hours ago, EdinPC said:I am afraid that I have just fried my entire PC
Seriously doubt your components are fried.
But I do have to wonder why you keep having these issues.
You didn't accidentally screw the PSU into the case using the wrong screw holes, did you? Or perhaps the wrong screws (too long)? This is, unfortunately, fairly common:
http://forum.corsair.com/v3/showthread.php?t=168396
