Skyrim: Vampire night Vision fucked up.. not working
lovingGamer
After installing this ENB, https://www.nexusmods.com/skyrimspecialedition/mods/4796?tab=description
and this Lights https://www.nexusmods.com/skyrimspecialedition/mods/2424/?
Vampire Vision is no longer working.. so at night i can't see jack shit..... :(
I think this is not fixable on my end, but.. who knows maybe it is possible
contact the mod developer with screenshots of whats hapening.  in most cases, they know what causing it and can tell you how to fix it pretty quick. ENB's are amazing, but holy fuck they cause problems.
This happened to me after installing my ENB
https://steamuserimages-a.akamaihd.net/ugc/103976952079355858/5B1ED9EFF616FBF43B213ED7F1BC4CF94618A68B/
emailed the creator, got it fixed within the hour(some creators are better than others).
EDIT: its definately caused by ELFX, looking through the mode, apparently its pretty well known that it makes nights SUPER DARK. its a feature apparently. best thing to do is to go into your enb settings and raise the ambient light intensity, or play as a kahjit
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
When i disable https://www.nexusmods.com/skyrimspecialedition/mods/2424/?
Then it works... Nigh vision, i think it's not ENB
Enhanced lights and fx restructures light scattering and sources. And it makes it darker to add a more realistic affect. They may not be compatible, not all mods are. You would have an easier time getting the answer from the mod creator.
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
I just deleted everything fuck it..  Do you maybe know how to find item ID but Mod item ID?
Only way I can think of is to have the item in front of you, open hit tilde to bring up console and then click on the item, should give you the prid number for it.
Or ask the mod creator.
— Grumpy old man
