driver_irql_not_less_or_equal 8700k Overclock
Solved by porina,
That BSOD can happen randomly when system is unstable for any reason. Most likely you either need more volts or less clocks. What is the actual voltage it is running at (under load)? 85C is hotter than'd I'd like for long term stability.
Edit: should add, I doubt it is the ram, it's pretty slow and safe.
eliasboss3 ·
Posted in Storage Devices5 -
arachi9 ·
Posted in CPUs, Motherboards, and Memory1 -
10
1
5
Yosh1 ·
Posted in Programs, Apps and Websites3 -
3
chrisjojo ·
Posted in Troubleshooting3 -
Rikothegamer ·
Posted in PC Gaming4 -
13
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
